I'm about to panic! I have a '99 996 C4.
Recently I had to add some less than desirable oil to my engine and put less than 100 miles on it. I parked it about a month ago and when starting the engine noticed it was now blowing white smoke and smells like crazy. Assuming it was the crap oil, I drained all the oil from the car yesterday and filled it up with Mobile 1. I started the engine back up assuming it would go away but it was just as bad. I haven't actually driven it yet, but had it idling for about 15 minutes in the driveway and it never went away. I also hear some clicking when at idle, which may have been there before, but I'm not sure.
So, what is this indicative of? I don't want to drive it if it makes something bad worse. But if it will go away after some time driving and recirculating the oil, then maybe I need to just do that. Help!
thanks,
Dustin
Might just be the aos... I had the same problem on the boxster and that's the most common diagnosis for smoke at start up... When mine went out it wouldn't stop smoking...
Be careful. I started my engine and had copious amounts of white smoke, water had been sucked from my brake booster into the engine. Bent a rod in fact.
White smoke is indicative of either water or coolant. If it "smells sweet", its coolant i.e. likely a cracked head or cylinder. If its water, likely from the booster or a small amount that got through the intake.
The best thing you can do is pull out one/all the plugs and see if anything drains out, then determine what it is.
