Hi. I drained the coolant and refilled (with the uview vacuum tool), but i think i messed up the process: while refilling, i let the fill container level get too low (it sucked in coolant a lot faster than i was ready for) and I think some air got sucked in. about 11 leters of coolant drained out, but only about 8 went back in. Resivior level is between min/max. I let the car idle for a while, reved it a little, heater on, bleed valve ope,, closed, etc. No change in fluid level and the car doesn't overheat. I don't want to drain it again. Should i just drive around with the bleeder valve in the ope (vertical) position for a while?
Yes, you can safely drive with it open for a week or so. Just be sure to check the coolant level daily until you are sure it not dropping.
makes sense, will do, thx.
