Does the service warning light illuminate when things like spark plugs or brake fluid reach either the replacement interval in time (years) as well as mileage?
Also the brake pad wear indicators-does it illuminate specifically as brakes or is it the general service warning and must be brought to dealer to figure out without a Durametric?
Spark plugs or brake fluid will not trigger a service light but will display a check engine light(amber) if there is a misfire and a red brake warning light if there is a hydraulic failure or low fluid level. Low brake pads will display a amber warning.
