My situation is a bit different from the other forum questions I’ve seen. My Ignition Key doesn’t want to lock or unlock the steering wheel. Yesterday the key wouldn’t begin to turn in the ignition and today the steering column lock wouldn’t engage and let me remove the key. Both times moving the steering wheel back and forth quite a number of times let me either start the car or get the key released. All the electrical functions ofr the Ignition Switch work fine. Is the Lock Barrel at fault? If it so, can it be lubricated or do I need to replace the entire assembly? Any help would be much appreciated.
Remove the electric part of the switch and try again, if everything feels good now, replace only the electric part, if not replace the complete switch.
