trying to figure out how to swap a blade or a pill
without destroying old or new one.
thanks,
mike
It's pretty easy. Just pop open the head and swap out the blade and pill. Here is a link to Pelican parts tech answers with pictures. Hope it helps.
GW
Changing remote head
exactly what I was looking for -- this is what I thought had to be done -- but figured I'd ask before I ruined a costly item.
thank you very much!
m
HERE are a few of my pics; link to instructions also there. Its pretty straightforward. :)
I like that FOB-post the part # or where you found that? (I'd be interested in one for a cabrio!)
Good info from both sources.
thanks,
mike
I just did it, flipped it from the bottom first, then used metal tweesers to pull it out, not as fragile as I first thought.
I then transferred it a few times to the GT conversion FOB but could not allign the buttoms, but the ignition did turn
only with that glass pill thing.
I am going to see if the local dealer will programme the new GT fob head from Pelican.
They guys who cut the key, as the dealer couldn't gave me a spare which solves my spare problem coz the only key
I had before was a very worn out original that only unlocked the doors 30% of the time.
One way or another a simple swap the guts of the GT / 911 Fob is not so simple, the buttons did not allign on my swap but
the part comes with "the gutts" so I will see if the dealer can sync them and the original key.
