Help
Is there anyone who can help me
airbag error code 5, 23, 27, 29, 194, 3, 20, 21, 46, 25
mvh
Krister
sweden
Boxster S 2004
Edited by FABIA777
Hello
I would be very happy if someone could help me
what to start looking Eftr wrong ..
Krister
Krister :renntech:
Edited by FABIA777
Help
mvh
Krister
sweden
Boxster S 2004
Krister:
The only one that looks like one of the classic airbag light codes is your number "46". There is a TSB on codes 45, 46, 48 and 49, all of which involve the contacts to the leads from the seat belt buckles and proper grounding.
IIRC, off the top of my head, code 21 is "ignition circuit, driver" which will set off the airbag light as well. That fix usually involves finding a shorted wire from the airbag assembly to the steering wheel, or faulty wiring inside the part called the "clockspring", which is under the steering wheel.
I know there are about 30 or 40 different airbag codes, but the above are the most common.
Regards, Maurice.
