My Durametric scanner is giving me a P0234 Fault Code, Boost Preesure Deviation. It feels like only one turbo is working. Anyone have any advice on where to start? The car had been running great, it sat for about a month then I started getting this fault code.
Possible fault cause
♦ Leakage at pressure hoses from frequency valve to the bypass
flaps
♦ Frequency valve faulty
♦ Vacuum modulators for bypass flaps leaking
♦ Bypass flaps incorrectly adjusted
So you have a leak somewhere or your wastegates are faulty.
