I just got a 2005 Boxster (Tip). When I press the front defogger on, the A/C compressor turns on, fan setting goes to max, and only get hot air from the top vents even when I have the temp setting on Lo. Is this normal? Shouldn't I be able to adjust the temp setting?
That is normal.
That is normal.
That means on hot rainy days, you have to put up with the hot defogger to clear your windshield? You'd have to manually cycle between A/C and hot defogger.
That is normal.
If you just leave on the A/C and only have the up arrow blower turned on... would this not defog the windshield as you desire??? I think that actual defogger button is just a one touch way to turn on the blower all the way up and on conditioned heat to defrost quickest... much the same as the max AC button is a one touch way to do the exact opposite...
