I have Durametric software that has many sensors that can be read either real time on my laptop or also logged to an excel spreadsheet.
Problem 1. I don't know enough about what is a 'good' number or a 'bad' number for some of these sensor readings.
Problem 2. Under what conditions should I record this info? IE. A short drive at different RPM's or just idle for a few minutes after coming up to operating temp's in the driveway?
Some conditions such as cockpit/outside temp's are silly while others such as O2 sensor volts (which I had a previous fault code for) may mean something. The software records up to 8 sensors at a time before you have to start another file name to maintain the cell names for each sensor. To make it easy, which are the 8 sensors that would give you an idea of the health of your engine? I didn't count them but there appears to be over 20 sensors that it can read in total.
If someone can give me an idea of what is the best testing situation to use, (a short drive or idle) I could post the excel file here for comments.
Right now the only problem I have is a start up idle too low issue (it wavers up and down from 400-600) that goes away in about a minute or so once the temp gauge appears to be moving upward. No CEL's but an old code concerning P0150/P0130 - something about voltage ahead of the cat's. I've cleared the codes and will drive the car for a few days and then recheck.
Edited by torontoworker
Codes mean there is a problem with
– Oxygen sensor
– Wiring harness
– ECM
So if only one of these codes were present, I'd say the first thing to do is borrow someone's O2 sensor and swap it in and see if the symptoms change. Even one someone took out because they were replacing in pairs when only one was bad would be a help in diagnosing. Check the wiring too to make sure it isn't frayed or a connection loose. Since the signal from the O2 sensor is used by the ECU to regulate the air/fuel mixture during the cold period of a start, it could well explain the problem with idle. Something as simple as the sensor not working until it gets warm.
But you have 2 codes and they point to different banks of the engine though to the same parts/problems and the likely hood of both failing at once is a bit far fetched. But if one has been failing for a while it cause the other to fail. Or it could be they both are just old and need replacement. Mine lasted 55k miles or so.
Always post the model year and miles on the car when posting a problem as it often matters re a diagnosis as the version of the firmware changes over the model years.
More on the sensors including prices and sources. No need to buy the Porsche branded part or visit a dealer to replace them.
I run a DashDaq hooked up to my OBD port and log
speed
RPM
Intake air temp
Spark Adv
MAF
Coolant temp
I dont have any base runs to offer (I'm in an 04 C4S)-but someone here might to use a comparo-
I log everytime I get in the car-so if something does happen, I have the last drive info for diagnostics-
I also set warnings for low collant temp (and high), IAT, Speed, RPM shift points, ect (blue is low, green is good, orange/Red is high).
I've only had the car for 2 weeks and have 6 files so far-now I need to build an xcl sheet to compare info (I'll share that when its done).
