I'm new to this forum and I have to say that I really like it.
After the german 911 Forums could not solve my problem I just try it here - maybe someone knows the problem.
Since about 4 weeks we try to get rid of the PSW warning light - Porsche and Durametric Tester says "booster pump".
We have changed the pump two times with no effect - including the bleeding with activated pump - the light stays on!!
Brake light switch : checked
Steering Angle calibration: checked
Fuses? : ok checked
Booster Pump: checked and replaced
what else can cause/solve that problem?
exchange the ABS HYDRAULIC UNIT?
exchange the MAS?
Thanks in advance
Oliver
I would start with a check up by PIWIS diagnostic tool, which have more possibilities. As you said, MAF, throttle body, brake light switch, ABS unit, steering angle sensor, centrifugal sensor, fuses, connectors , wiring's and more, are all connected to PSM.
:welcome:
Please tell us the exact model and model year of your car.
Also, if you have a fault code number(s) please tell us those.
Hi Loren,
sorry that I forgot theise details:
04/2000 Carrera 2 Convertible
The PIWIS Tester shows the same message "Booster Pump" but we have replaced this pump twice
- I have to check again for the code
thanks in advance
Oliver
booster.pdf
ABS_1.pdf
Overviev_code.pdf
Edited by PROTEC
