hey guys i need to know how to disable the airbag light im going to install a momo steering wheel without airbag thanks .
opps i forgot to add my cars a 2001 911 turbo
Got two options for you to go with the black tape -
1. I find the black tape to be unsightly - so you can remove the bulb ;)
2. Or, you can wire in a 2.9 Ohm 1/4 watt resistor.
I did the resistor for a while on my track car after putting in a MOMO wheel but before gutting it for a cage. It worked fine - no problems at all. I learned it from 944 racers.
You can find a 2.9 Ohm resistor through special order, but I just made one, albeit with the help of the electrical engineer that lives next door.
I will look around - it is a long shot, I might still have the set up I used.
Edited by ericinboca
