<note we figured out which bank is Camshaft Sensor 2 -- but I couldn't change topic name>
99 2.5L Tip
Just swapped engines and rebuilt the top end.
Trying to get it to start..... cranks, but no go.
Have spark and fuel pressure (have not checked fuel injectors)
< Just found out that it started for a couple seconds then died out, won't start again >
No CEL but 3 codes
P1602 (yes the battery has been disconnected :-)
P0102 MAF -- we've cleaned it - might have to swap it.
P1397 -- Camshaft Position Sensor -2
Bank 4-6 Camshaft Position Sensor was swapped with one from
another engine -- but still same response and code.
Possible both are bad (1st one and swapped one?)
Suggestions:
thx,
Mike
Edited by txhokie4life
The CMP sensor 2 is needed to identify the position of the camshaft for cylinders 4 - 6.
– No power supply.
– Break in wiring.
– Short circuit to B+.
– Short circuit to ground.
– CMP sensor faulty.
