Can someone tell me what is the clearance needed to fit a jack under a Carrera S for tire change?
Should be approximately 4 to 4 1/2 " maybe a tad more but less than 5". I use a Sears floor jack with the jack pad attachment ( round metal receiving piece that fits into a hole on the end of the jack ) removed and in it's place use a piece of thick rubber mat to protect the jack points on the car. A hockey puck will work also depending upon the jack you are using.
