The vents in the rear pillars go from being weak to non existent in my 04 Turbo. Is this a common issue or do I need to do somthing get more air flow back there.
The air flow is weak in the back with the standard A/C unit, a double unit (option) is the only solution for a good result.
Can you upgrade to rear A/C or double unit ?
Nothing is impossible, but the cost will be much, i'm relatively sure about that.
