where is the outside temp sensor located. yesterday it was 90 deg in Los Angeles and it was reading 135 deg. and the display said theat there was an outside temp error. i guess i need a new one. any one else have the same problems, it always read about 10 deg high. oh i have a 2003 c2. thanks in advance for all your advise.
Located in the front area of the passenger side radiator cooling air intake. An open circuit would indicate -30F a sorted one (apparently) 135F. Unusual for the fully epoxy encapsulated thermistor, check wiring first.
