Both of my bulb is gone been looking for a way to change the Headlight bulb for more than 2 days I just couldn't figure it out any instruction pls
Really simple and there is instructions in the owners manual. Little tool in the luggage compartment that you use. Once you find the tool, open the hood, look for the little plastic circle covers behind the headlamp assembly (they'll have a picture of a headlamp on them), pop them off, stick the tool in, turn it. Whole headlamp pops right out.
Take the headlamp assembly out, open the back, replace the bulb. Simple as pie.
I just did this yesterday and the instructions in the owner's manual are not very intuitive.
Once you remove the plastic covers (to the side of the headlamp, not behind), you can peek in and you will see a light colored steel nut, and the tool from the luggage compartment slides right over it (inserting it into the hole at a 45 degree angle) and by turning it, the whole headlight assembly is pushed out.
While I was in there I replaced the rubber gaskets fitted around the assembly. They had completely disintegrated.
JP
JP
Hi mate, my friend asked me to post here, just wanna to ask if it is hard to get a HID kits on this car please? Many thanks!
