Hi, new member here with probably a dumb question, but...
I've got a '03 Boxster S that I've recently upgraded the standard lights to the Litronics I purchased online. Opted not to install the control unit that I received with the lights. Did the install and high/low beams and turn signals work fine.
However, the parking lights don't function. Does anyone know if the parking lights are controlled by the second connectors that would go to the control unit or should they have worked without?
Figured I'd ask before I bought new bulbs.
All lights in the headlight should work. All the control unit does is to permit the low beam xenon bulb to rotate up a few degrees when you turn on the high beams.
