Hi-- 2004 911 anv. Navigation is out of wack -Doesn't know where I am. Any reset???
Edited by RIC480
Hi-- 2004 911 anv. Navagation is out of wack -Doesn't know where I am. Any reset???
Have you got any codes? Have you had any maintenance or disconnected the battery? Changed a tire?
When the power supply is disconnected (terminal 30), the built−in GPS receiver loses the so−called
almanac! The almanac stores the satellite orbits and ensures fast location of the individual satellites when the system is
started.
Procedure after changing a tire:
Drive on a motorway if possible at a speed greater than 60 km/h for a distance of approx. 50 km (calibration
of the distance measurement).
Procedure after the power supply has been interrupted:
Procedure after the power supply has been interrupted: Switch on the PCM with a free panoramic view for
approx. 20 minutes (to load GPS almanac).
started.
No codes -However changed all 4 tires -Will try your calbration
:huh:
started.
Thanks all fixed !!! :)
