does this just plug in..... or do you need opc to reprogram
also i have notices the sim from my iphone has some new numbers and isnt updating how do you delete sim records completely and then it can just reload from scratch, i only have 70 or so contacts there are not to many
Anytime you add or remove items from the MOST fiber optic bus system - it is best re-initialize the system and verify the components with a PIWIS tester.
thanks loren any info on the fit or part number i cant see in it the tech equip book as a single item i wondered if just factory fitted... only reason i want is h/f sound not great and im on phone a lot in car !
