You might find the photos on this site useful. this is the guy who rebuilt his "S" motor on youtube. site is 986fix.com. I think my 98 Boxster has a blown head gasket so I have been looking into engine removal procedures.
There is also some good videos on u-tube...search boxster engine removal.
Does anyone have experience with setting the timing? Manual calls for tool 9612 to attach to the cam, but from what I can tell, it only helps line up the notch in the cam. Something that appears to be completely possible without the tool.
I am also struggling to understand the need for tool 9599; the 3 auxiliary chain tensioners. Do the regular tensioner bolts not preform the necessary task? One of the tool sites I saw them on refers to them as "optional" tools rather then "required"
  • 4 weeks later...
An update:
Replaced the following in my 1997 2.5
-All serpentine pulley bearings and belt
-AOS with new style
-All spark plug tubes and O-rings
-Both sides camshaft timing chains (endless) and Varia cam wear shoes
-All O-rings in Power Steering pump. Actually had no fluid in resovior when disassembled.
-New O-rings in left and right bank oil pump.
-New RMS
-New IMS bearing. Replaced with exactly same type but pulled bearing seals to allow engine oil in.
-New J-tube and O-rings
-New clutch, throw out bearing and pressure plate
-Front engine mount rubbers
-New rear stabilizer bushings
-New plastic piece where you add oil, old ones was cracked and allowed oil on top of engine
-New dipstick plastic tube. Old one was broken.
-Drained and replaced power steering fluid.
Parts were about $850.00 from Sunset with the clutch kit being the most expensive...(around $400.00)
Car started right up after re-install. :D
Car runs shifts and idles better...well worth the time and pain...
