First of all I want to say hello to all of you. For more than 1 year I am following this very informative forum, because since I was a kid I promised myself to buy a Porsche 911 one day. Last week that wish became true. I received my MY07 997 cab after having searched for "the right one" for almost 6 months. The only compromises are the missing PES and missing park assist.
The car is still in excellent condition, with less than 8k miles. The previous owner took care of her, including a protecion film on the front, on the headlights and side mirrors of the car.
I really like the illuminated door entry guards. They look very nice when it's dark.
Enclosed some pictures of my new family member:
After having read the TSB about the PES retrofit here in this forum, I am convinced that I can install it myself with some help, because I want to turn it on/off with the sport chrono button.
As part of the "deal" I purchased the complete PES system (part # 997.044.200.02) at a fair price from the dealer I bought the car.
btw: for those who plan to buy the PES retrofit package for the 997/1, hurry up, because Porsche increased the standard price from ~$2,200 to ~$3,400. The part number was superseded into 997.044.201.03. There are only some few dealers left who have the PES with the old part number in stock …… and do not know that they cannot re-order it for the lower price.
Here are my questions:
1) Although there are some good explanations in the TSB, can somebody post some pictures about how the vacuum lines for the PES are laid and attached in the engine compartment ?
2) is the Engine Control Module exactly at the same place as on a 996 cabriolet ? (I am asking because I found some helpful post in the internet how to reach the ECU on a 996 cab, but no post for a 997 cabriolet so far)
3.) which one is chamber 14 of connector C
4.) which one is chamber 8 of connector A
Your help would be much appreciated. Thanks in advance.
Very clean car. I cannot help. You may want to look into
a day of working on cars in your neighborhood.
I know thaty they do a few of these a year in
northern California.
Paul
Paul
Neighborhood ? What do you mean ?
I live in Michigan which is not much a Porsche invaded state like California, so unfortunately the Porsche community is missing here.
Congrats on the new car!
PSE is awesome! You really don't need to hook-up the on/off function IMHO. Makes the install that much easier. You will like the sport mode (loud) all the time. But, I know a lot of owners like the on/off function. It's personal choice, I understand.
I did see that the PSE pricing has gone WAY UP! I wondered about that. It is now 2X's the price I paid for the parts (from Sunset Porsche) over 2-years ago. I had the very first PSE retro-fit on a 987S in the USA in April of 2007.
You don't need park assist in a convertible! The top sould be down 99.5% of the time...and that makes it that much easier to see when parking!! :) Plus, it saves weight, and increases HP. :P
......You don't need park assist in a convertible! The top sould be down 99.5% of the time...and that makes it that much easier to see when parking!! :) Plus, it saves weight, and increases HP. :P
That's exactly why I want the park assist. That makes the car even more fast ....at least backwards. :D
Regarding the PES I heard it is sometimes too loud and annoying when the the top is down. Therefore I want to have the freedom to decide myself …. when I am going to wake up my neighbours on a Sunday morning.
Touche! LOL.
It really is not that loud. When I leave my house at 5:00 AM on a Saturday or Sunday morning it's just fine. Plus, you get that nice cold-start-up gurgle! I keep her below 4,000 RPM until fully warmed-up, and by then I am nearing the clover-leaf and away from the sleeping neighbours.
Even after fitting the PSE yourself you will still need porsche to activate the control using the workshop PWIS unit. Depending on the age of your car there will be one of the wiring schemes that is suitable. The TSB for retro fitting the PSE is available for subscribing members of the site under the TSB downloads section. I would suggest if you are wiring this yourself to include an overide switch to allow the PSE to remain active at all speeds avoiding the 20 -40 mph cut out. This would involve placing a switch on the line back from the solenoid into the rear ECU/ DME.
I retro fitted the PSE to my boxster , the control unit and solenoid wiring is identical to the 997 (the rear DME and solenoid is the same part number) , the only difference being the physical location of the DME and solenoid. If you have a very early 997 (2004 model) the DME will not have the 20-40 mph cut out , though you will not be able to confirm this until the unit is wired up.
Once you have removed the plug terminal strip from the housing (they slide out sideways) you can see the plug is labelled with the chamber numbers. Make sure you buy repair pins from VW to populate the positions you want to connect to. If you use the wrong type of pin they don't locate properly and can be a devil to get out (see pic) Repair pins are a few cents each so not expensive and can be bought with wires or blank with either gold or standard contacts.
Here is the plug and play kit I made up with overide switch
One option to mount switch under handbrake
Other option to mount in ashtray
Edited by berty987
LUZY V8
Did you ever get a pix or install instructions? If not, I have a pdf copy of the official Porsche install instructions. Email me and I will forward them to you.
Harvey in MD
Harvey in MD
Hi harvey,
No unfortunately nobody posted somepics so far about how the PES vacuum lines are laid in the engine compartment.
The installation instruction I have, is the according TSB you can find in this forum.
I will send you a PM. Let´s see if you have some different than that.
Thanks for you help. :thankyou:
I found a good link on how to access the engine control unit:
http://www.wit-usa.com/sms/db/smarttop/ext...997_v4.0/en.php
btw: I like that smartTop module
Edited by Luzy V8
I know I know.... :offtopic:
Me too, I like that smartTop module! The functions should come in handy and installation seems easy enuf.
But it's a little steep @299 EUR!
Marc
I would love to see a pdf copy of this also, I also want to get the parts to make the PSE active and inactive with an overirde button. Could you email me a copy at kwuster@gmail.com many thanks.
LUZY V8
Harvey in MD
LUZY V8
Harvey in MD
TSBs are available here for Contributing Members to view.
TSBs are copyrighted material of Porsche (PCNA) and Porsche AG.
I own my 997/1 for some weeks now and I love it. But it's hard to comply with the speed limits.
I have some questions which I didn't find any appropriate answer in the owner's manual:
#1) is there any way to set the headlights to turn on automatically when it's dark ? I don't drive with daytime-running-lights and I am wondering that in MY2007 cars you still need to turn on the headlights manually. Is it maybe a coding which can be chnaged with PIWIS or Durametric ?
#2) I wanted to see where the tire repair kit is, so I removed that cover in the trunk. I found the repair kit, but I was wondering why there were so many other empty spots. Even the towing lug is missing. Can you tell me what typically is in the two spots marked with red arrows in the attached photo ?
PS: Is there really nobody who could provide some photos about how the vacuum lines of the of the for the sport exhaust valve actuation are laid in the engine compartment. (Yes, I do have the TSB with the description, but real photos would help to avoid mistakes)
To enable the PSE to be on all the time pull the vacuum hiose with the red arrows. Make sure to plug both open connections to prevent debris.
Loren, I had the is picture saved from RennTeam.com. If that is not allowed my apologies and you can delete my post.
Phillipj
Edited by phillipj
Thanks Phillipj. But I do not want to enable it all the time. I want to activate/deactivate according to spec.
My only interest is to see actual photos how the vacuum lines are routed from the mufflers through the engine compartment to the change-over valve. In the TSB it is described like "....Underneath filler neck for hydraulic oil→above air conditioning compressor→underneath fuel collection pipe (cylinders 4–6)→between intake pipe adapters for cylinders 4 and 5→rear muffler holder, right.
Auxiliary line for left rear muffler (997.111.612.00): Underneath filler neck for hydraulic oil→underneath throttle housing (electronic throttle adjuster)→intake air distributors for cylinders 1–3→rear muffler holder, left....
I would prefer how this actually looks like.
