I have a slight issue with my 997 c2s.
The door carpet at the bottom of each of the doors (on both sides) are saturated.
Does anyone have any ideas what could be causing this and how to rectify?
Much appreciated
Marc.
You left your doors open in the rain or maybe your drain lines are plugged. Cleaning them is an easy DIY. Ed
Defintely not the former, so must be the latter :)
Any pointers (links) as to how to clean the drain lines?
Marc.
Marc.
I would recommend using an air compressor to clear the lines. FWIW I had this exact same problem
Check out my thread on rennlist
http://forums.rennlist.com/rennforums/show...eferrerid=64782
