The AOS Boxster/Carrera is different (Carrera is partial water heated) the replacement procedure also, from more difficult (manual gearbox) to much more difficult (Tiptronic).
I'll post up a link I found tonight (It's saved on my home PC) I know you need to remove the driver side intake manifold and it's a about a 10 hour job if you DIY...
Suncoast parts just posted a Newly available Cup Motorsport version of the AOS which will work on boxter/Carrera that seems to be a lot more robust...I just had my Porsche mechanic install a new OEM AOS on my 2000 996 C4...a recent track day overwhelmed my original AOS and it appeared I had destroyed my 3.4L but it was just the AOS.
Edited by Xeattle
