Well, my car is extremely low. The reason this is relevant is because I hit a protruding man hole cover and broke an elbow like structure which attaches to one of my coolant hoses underneath the car on the drivers side. All that was left when I looked under was a hanging hose, pieces of the part and the gasket and bolts. It looks alot like the thermostat housing and therefore I bought the assembly only to discover that it didn't fit. I'm attaching a picture to this msg. If anyone could help me identify the part I would greatly appreciate it. Thanks everyone.
Car is:
1999 Porsche Boxster non S
with a 3.4 996 Engine conversion
5spd Manual
Looks like the cover for the oil pump cooling and heat exchanger to me.
I would agree -- and the thermostat is on the other side.
Might want to get yourself one of those 4 wheeler skid plates while your at it...... Have to be cheaper than all these parts you keep tearing into!
That or a sheet of plywood :-) Some folks leave a bread trail, others dripping oil, you'd have sawdust to follow home :-)
mike
