I have been reading the various threads on wheel spacers. I had always thought you only used spacers when you changed wheels. :huh:
When looking at my car my immediate thought is that it would look better with spacers on the rear. I have the stock Carrera 5 spoke 19's. The rear wheels don't really fill the wheel well as much as I would like.
If I were going install spacers which ones would I order? Is 5mm the norm? Is it best to order the Porsche OEM or is there a aftermarket alternative? Don't want to do anything to void my warranty.
Any insight and suggestions would be appreciated.
Edited by phillipj
Phillip:
Check out "allsprings.com". They carry H & R spacers which are made from a lightweight aluminum/magnesium alloy AND are TUV approved. Great for less unsprung weight and safety.
Regards, Maurice.
I bought the porsche spacers. They
came with longer lug nuts. Bigger
then Porsche might case problems on the half shafts.
Just make sure of the longer lug nuts.
I do not think the spacers made the car faster.
I do not think the car handles any better with the spacers.
I do not notice any difference with the wheels fitting better.
I think that lowering the car would look better but I did
not do this because the car is to redady to low.
Paul
But what size do get? It looks like the H&R site recommends 7mm. Is that right? I'm strictly doing this for aesthetics. Not for speed or handling.
Anyone know the correct size for the 997?
