Are any modifications required to install a set of 997 seats in a 2002 996 C2? I'm curious about the rails, electronic controls, seat heaters and airbags.
Any info appreciated.
I remember a thread on this not too long ago. I beleive that the rails are the same but the connectors for power are different. I recall that it's not an easy swap. Hopefully somone else will chime in with more info.
Thanks for that reference. It does confirm they are a direct bolt-in. However, it doesn't really say if the electrical items can be made to work. And, if so, HOW? I found basically the same thread on 6Speed and will try to get that person to give more wiring details.
Good luck,
I hope you can figure it out
