My "new" 2000 Cab Tip drivers side output shaft is leaking oil. This is the left side axle/drive shaft seal and looks like it could be a big deal to repair. What are my opitions with this problem?
Thanks for the info. I think your right about removing the engine. It has 90k on it and could use some attention; this would be a good winter project. Would you know of an engine removal pocedure I could follow? Thanks, Ron
:wacko: "Removing the engine"? I'm sorry but I think you might have misunderstood what I'm saying. You definitely don't need to remove the engine. That would be a bunch of effort with no return. If you really want to take the engine out for kicks or something than a Bentley manual is a great reference guide but you should definitely leave the engine in for this job.
Well, i'am glad we got that clear! I understood it as removing the engine was the easest way for this problem. Thanks for staighting me out. I did look at the Bentley website for guidance on this differencal leak and could find nothing of help as far as detail. I wonder if i'am getting in over my head? Thanks, Ron
