The LCD backlight on my CR-220 died, (I can still read everything in direct sunlight, and everything works) I assume it's the bulbs, but could be the dropping resistor. The faceplate LOOKS easy to open, but before I delve in there, I figured it was worth asking on the board if anyone has ever replaced the backlight. For a few bucks, it's worth repairing, but I sure would never pay the $70 that is being asked on ebay for a face plate. I have a CDR-220 to use in the meantime, so no big rush at all, but I like to use cassettes at times. TIA.
I would check with SW Stereo (www.swstereo.com) and see how much they want to fix it, or if they can give you some DIY tips.
I Would clean the contacts on the dispay facepate and see if that "rejuvenates" the back-lite ?? Beyond tha tyou could try and reach Becker and see if they offer a repair service that is cost effective. Good Luck!! :cheers:
Demosan
Well, I opened it up and there are no bulbs, it is LED lighting, 3 banks of 20, plus 1 in each corner, +2 where the alarm "set" red led is. The flashing red is still there, it's just the white ones (the yellow color is a film over the LCD display). So sinc eit's impossible for 65 leds to burn out, it has to be a dropping resistor on the supply circuit, or what appears to be a fuse labeled "4.19". I'll have to take my meter to is and see if has any value. If it's open, then I'll have to open up my working CDR-220, and see if it has a matching component and measure it.
Actually, that was still very helpful. I hadn't thought to maximize the pressureon the zebra connector by putting the lower tabs in tight first. Good advice. I don't suppose you still have the extra funky faceplate you want to sell cheap? As long as it lights up, I can build one good one around those two, same way. All my buttons are in great shape.
  • 7 months later...
Did you ever get your backlight fixed? I have the same problem. While the DIY is helpful, since they are LED backlights I'm looking for info on what was the root cause.
I've tried many times to fix these types of radios in the Porsches and BMWs too - never quite succeeded, and the best solution was to often purchase a broken unit from eBay (broken for a different reason) and swap out the face plates.
-Wayne
