Airbag light is on and Durametric lists code 31 - ignition switch passenger airbag as the cause. A while back I had a window regulator issue on the passenger side and while disassembling the door panel I admittedly broke the airbag connector. While the vehicle was in service for the regulator they replaced the airbag connector in the door. Light just came on last month, about 2 months after service. It may be unrelated to the connector repair but I thought I'd mention that.
Can someone point me towards where the problem may lie? Vehicle is a 1999 Boxster.
It is a very simple circuit. Either a bad connection or a bad airbag controller.
If you are not familiar with the dangers of handling airbags then have a professional do the repair.
Don't know if they would fit, but I have passenger airbag and controllers out of a 2004 986S. If you want part numbers, etc., PM me.
