Hi all,
I recently went down to a local tyre shop to have the rear toe and camber checked and changed, as my car doesn't feel as sure footed as it should at higher speeds :( . The technician unfortunately couldn’t find a way of adjusting it. So I am wondering is adjustable or is it an OPC only thing?
Giles
Edited by mec
I think you need to find a better alignment shop. The rear toe is definitely adjustable. There are eccentric bolts for adjusting rear toe and camber. Apparently there is some interaction between the settings. If the car has been lowered, achieving the proper toe may require 2-2.5 degrees of negative camber.
