Would fitting a set of 6mm spacers change my alignment specs?
Thinking from a simple geometry point of view, all it does is widen the track. The toe/camber setting should still be the same, right? Anyone got any thoughts?
Also, would spacers like this affect the wheel balance? It doesn't look rotationally symetrical:
http://cgi.ebay.com.au/MAG-WHEEL-SPACERS-x...id=p3286.c0.m14
6 mm spacers willl not affect your alignment.
Here is a site that sells TUV tested spacers, which in this care are made of an aluminum/magnesium alloy and then hard anodized: http://allsprings.com/trak.php
I recently bought a set and they are of excellent quality.
Regards, Maurice.
