On my 987 Cayman, 2006 model, both front door windows, automatically lower when you pull the door handles but they do not automatically go up again when you close the door. Hence the windows are not totally closed and a small gap is left at the top. As both windows are exhibing the same problem, I thought it would be unlikey that both windows have regulator problems etc?
Edited by ruudx2
did you try putting them all the way down with the auto-window switches and then all the way back up to "reset" the memory of the window positions... I know sometimes this works.
