I have a 2005 997S with the sport chrono and i used to be able to see the chrono option on the speedo display. For some reason it is no longer visible with the other options like oil, etc. Any ideas how to get it recognized again?
Might need to be reset. You could dis-connect the battery
for about five minutes and see if that works.
You will have to reset the radio and you will need to teach the car
how you drive.
Good luck.
Paul
Thanks Paul. How do you reset the radio?
how you drive.
Good luck.
Paul
You will have to set your favorite radio stations.
All your bass and treble settings will go back
to factory settings.
Paul
