I have an '09 C4S with satellite radio. I am supposed to be able to change my music selection using the left lower lever on the steering column. It works perfectly for FM radio and CD's but intermittently it will not function for the satellite radio. When I active "Audio" with the lever and Satellite Radio is active on the radio sometimes the onboard computer screen just goes blank. At other times it works perfectly. The dealer "reloaded the software" to correct the problem but it still is an intermittent problem. This occurs probably about half the time. It's not a big deal but it is a function that I paid for and it doesn't work. Has anyone else had this experience?
MWS
MWS
How about when you select it from source button on PCM? I have multifunction wheel and it works fine, have never use the stalk to select it.
