Hello, 2002 with exnon lights. Left front single buld swapped and no change. Not working with 4 way flasher either. relay changed. The car wiring to the headlight works fine. When doing a wire check IN the light assembly it shows a shot inside the unit. All bulds have been swapped with same results. Can I take the whole assembly apart ? Info Please.
Is there a repair shop that I can send the unit to for repair, complete info please. Can I get a rebuilt/swap unit somewhere ?
The little 5 watt buld also is not working.
Thanks for any info Cb
