I'm considering putting a Brey Krause rollbar extension on my 03 Boxster S. Has anyone done this? Does it look dorky? Is it easy to install? Is the optional padding necessary? Will the Windstop fit once the extension is installed? The BK website has instructions for the installation of all their products but there is nothing about the rollbar extension.
I know adsach has one - what do you think?
Quite a few of us who take our Boxsters to the track have installed the Brey-Krause rollbar extension. How it looks is subjective. It's easy to install...20 minutes maximum, less once you know how. Two bolts on top, two bolts for the shoulder belt brackets, 4 more for the sides. The optional padding kit, or something like it, is VITAL. It would be very dangerous to drive without padding, because the roll hoop brackets are right behind your head and in a minor rear-end collision you would be asking for a cracked skull. The center windstop will fit with the extension on, but the hoop wind screens will not unless you cut them to fit around the bracket. (Of course, when you remove the extension, everything fits back in place.)
Here is a page of mine with photos and more information than you need:
More B-K Roll Bar Extension Info
