My power steering pulley is making a really loud squeeking noise and want to know if I can change the pulley or is there a bearing assembly I can get with the pulley that will eliminate the noise caused by it beeing worn out, or do I have to buy a new power steering pump? I changed the drive belt, incase ppl are thinking thats the noise. Let me know guys thanks.
Remove the belt and inspect all of your pulleys for wobble. A failed pulley can do major damage to your engine and/or alternator.
My car is a 97, it has 95000km on it. The noise was definetely coming from the power steering pulley when i had the belt rear engine cover off, I could definetely tell, so will replacing just the pulley fix this problem? I'm going to remove the belt this weekend, and check it all out and see what info I can find about this problem. Any other insight guys?
If you are sure it is only the power steering ( I still suggest that do you what said) then you likely have a bad power steering pump bearing. That means a new pump.
Ok, thanks. How hard is it to change the pump? Anybody able to tell me their experience in that? Or is it pretty straight forward? Is there a bleeder valve on the pump to get the air out after? Let me know guys, thanks.
Any further insight on replacing the power steering pump guys? If someone could give me quick directions or, a link on a DIY article that would be well appreciated, let me know guys, thanks.
