Original Equipment rotor thickness......Anyone know this?......and I wonder what is considered below exceptable.........I never get there cause I have the cracks long before.
Edited by GreggT
I don't know the original thickness but the wear limits on 996 and GT3 is 0.6 mm.
Thanks........that helps....pretty easy to see the dif between where pad has contact & not.....both sides would have to add up to that 6mm......Loren you do mean 6mm (ie 1/8" ea side)?
Edited by GreggT
Here I found this data prieviously posted by yourself Loren......thanks.
Here are the specs:
Brake disc thickness, new -- front 28 mm, rear 24 mm
Minimum brake disc thickness after machining* -- front 26.6 mm, rear 22.6 mm (* The brake disc must only be reworked symmetrically, i.e. from both sides evenly.)
Brake disc wear limit -- front 26.0 mm, rear 22.0 mm
Peak-to-valley surface roughness of the brake disc after machining, max. -- 0.006 mm
Thickness tolerance of the brake discs, max. -- 0.02 mm
Lateral runout of the brake disc, max. -- 0.03 mm
Lateral runout of the wheel hub, max. -- 0.03 mm
Lateral runout of the brake disc when installed, max. -- 0.06 mm
Those specs are for 996 brakes - Here is the same info on the GT3 brakes since they are about the same as TT/GT2:
Brake disc thickness, new -- front 34 mm, rear 28 mm
Minimum brake disc thickness after machining* -- front 32.6 mm, rear 26.6 mm (* The brake disc must only be reworked symmetrically, i.e. from both sides evenly.)
Brake disc wear limit -- front 32.0 mm, rear 26.0 mm
