Hi I need the part number for the triangular exterior mount for the self dimming mirror with memory seat. There are 12 wires in this mount. It is for an 04' Targa. Thanks cmg
Which item?
I really only need the wiring harness which appears on the right side to be #14. I was under the assumption that it could not be purchased unless one purchased the triangular base with wires which appears also to be #14.
Which item?
Thanks Loren but just in case I can't get that could you give me the number of the base &with the harness?
Which item?
Left or right side.
BTW... when Porsche does not sell a part the part number is blank in the listing. And, my listing was updated 3 days ago (Oct 2009 Listing).
That would be for the left or drivers side. Also is their a part number for the combination interior self dimming mirror with integrated rain sensor which runs from the behind the dome light to the relay switch & control unit for the same car or is it part of the main harness? Thanks.
