My passenger side cooling fan doesn't come on. It works with an external power supply. I've checked the fuse. Where's the relay? Is the temperature switch the same for both fans?
Are you overheating? I always thought they came on individually But I can't be sure. There are only 2 place for relays I know of and the one closest to the fans is above the fuse box. Someone else will have to tell yo which one(s) it is (they are).
PK
Wiggle the ignition key. Sometimes it is a faulty ignition switch.
With A/C on high, I believe both fans should be on. Mine had a bad connection at the fuse...fuse was ok but fuse was loose in fusebox. Try wiggling the fuse with the A/C on high.
