Hey guys I have 2 unknown fault codes in my car. I am using an Autologic computer. The codes are #2500 and #2513. Does anybody have the descriptions and the procedures to solve the problems?
Can you have it read with the Durametric software or a PIWIS tester - those codes do not come up in my listing?
Unfortunately our Porsche dealer here in Honduras went belly up. They were terrible anyways, so that's the reason I got te Autologic computer. Thanks for the help tough, you guys have been great. I have to say, RENNTECH is rally a great forum.
Loren:
Got a new read on my computer. I have a fault code P0420 "catalyst system efficiency below tresh hold bank 1". Any ideas? Again I got using an autologic system Thank again
P0420 Catalytic conversion
Possible fault causes
- Oxygen sensors in front of and behind catalytic converter swapped (position in exhaust assembly)
- Valve lift error
- Aged oxygen sensor behind catalytic converter
- Catalytic converter faulty (pre-catalytic conversion rate too low)
You could have a damaged cat.
