Has anyone had this problem? I am in south Florida and on occasion the door handles are VERY hard to pull open from the outside. Do I need to pull the inside door panel to grease any fittings or can I access it by the latch area?
With the inside panel removed, you have easy access to all components (lock, back side of the outside handle, etc.)
Any tips to removing the panel? I attempted it once but I felt there was a something still holding it on. I pryed the clips at the bottom, removed the cover off of the grab handle and removed that screw and I believe there were two screws at the bottom of the arm rest. Anything I'm missing?
