i can see that the only part required for retrofiting voice activation on PCM3 is the enabling code and new turn indicator switch (i have microphone already). Lets assume i have the code. the only difference with turn switch from a non-voice car is a button at the end of it. Looking at TSB I cannot see any cables that connect the turn switch and all other switches on steering wheel column to PCM. can anyone tell me how it is connected? are all signals go through CAN?
