After installing the fabspeed x-pipe sport cat. The car has a fault code of P0160-O2 sensor behind cat converter-bank 2. Where is this O2 sensor locates? Is it in between the manifold and cat or cat and muffler? Is the cat from driver or passenger side?
thx
M
P0160 Oxygen Sensor After TWC, Bank 2 – Open Circuit
Possible fault cause
- Open circuit in signal wire or ground wire of oxygen sensor
- Oxygen sensor heating faulty
Follow the exhaust on the right side of the car. It will be the sensor after the cat on the right side exhaust.
thx
M
Off the subject but how do you like the x-pipe? I am needing to replace my cat and was thinking of this option.
GranburyChuck,
the X pipe is a good investment. It is lighter, sound a bit louder and most important that the car felt faster.
M
M
