Hello,
I am having my engine replaced and will have the opportunity to inspect the old engine, I would like to know where the serial number is located on the engine. Also, where would I find the serial number for the engine printed in Porsche literature that came with the car.
TIA,
Duane
Im not 100 percent sure but I believe its stamped on the bottom either on the oil pan or right above it. I've seen it before but I cant remember right now.
Hello,
TIA,
Duane
The motor is bad and will be sent back to PCNA. Diagnosis was worn rings and bent valves. Dealer indicated possible over rev, Porsche zone rep agreed that the damage was not caused by over revs. Possible causes: Low oil or overheating (neither occurred) or a foreign object got into the engine or could be a piece of carbon dislodged from within the engine. Car had 105K miles, engine started smoking, no other signs of a problem prior to being towed to the dealer.
Duane
