Hello Guys,
I have 2001 Boxster S and 1999 996, and trying to activate OBC.
I installed factory lever switch and all the wiring.
From the research, I found there are 2 different type of connection by year.
Then I went to the dealership to activate OBC.
They said they couldn't even access into the section of activating OBC.(can't log in?)
I could have activate on 996 no problem, but not the Boxster....
I connected different way than 996.
Anyone has similar experience?
Anyone knows the solution?
Edited by pearl_porsche
Hello Guys,
Please read the thread on OBC and cruise control.
Really bad dealer if they don't know this - they need to make sure the order type code is programmed into the DME or you can not change anything.
This is a 996 coupe for your MY01 Boxster S it should be 986320
