My friend's 2002 ROW C2 Manual Cab had its CEL come on yesterday evening. On my fault code reader, it read P2096 and P2098 which is the Post Catalytic Fuel Trim Bank 1 and 2 System Too Lean code respectively. It would be pretty unlucky to have both lambda sensors fail together especially only 1 year and 10000 miles ago he had all 4 replaced by the Porsche centre. Could it be the MAF? I've cleared the code and it hasn't returned so far.
Also, on the same day he was driving, the interior lights came on by themselves and then later when he parked the car, as he was walking away, the roof folded itself. Obviously not good on the street. Its now done that twice. All control units under both seats are dry. Any ideas?
P2096 Signal Delay Time for Oxygen Sensor Ageing - Above Limit
P2098 Signal Delay Time for Oxygen Sensor Ageing, Bank 2 – Above Limit
Possible fault causes
- Oxygen sensor
Mine definitely says P2096 Post Catalytic Fuel Trim Bank 1 System Too Lean, P2098 Post Catalytic Fuel Trim Bank 1 System Too Lean
My information comes from the Porsche DME 7.8/OBD II service manual for MY2002 996 Carrera.
Where are you getting your information?
Its from the fault code reader. I should have looked up the service manual that I have to cross-check the code. Just goes to show how lazy one can become when presented with tools that give you extra features like code definitions. Doesn't mean that they are always right.
  • 5 years later...
Hi Loren and John,
Does P2098 point to the bank 2 pre-cat sensor? The Bentley repair manual says so but I just want to double check with you guys. TIA
I have corrected that - it was a mistake in the early OBD manual from Porsche. All of the latest show bank 1.
Got it. Thanks!
