I have a 1999 911/996 with 18" wheels (front 18x8 and rear 18x10) with front 225/40-18 tires and rear 265/35-18 tires. Recently I purchased another set of 18" rims with front 18x8 and rear 18x11 dimension which came off of 2002 C4S. Is it possible to install 245/40/-18 and 315/30-18 on the new rims? If yes, what are the requirements? are spacers required?
Ben
Ben
I am running 245's on the front 18x8 rims and 285's on the 18x10's (the ones that came standard). My suspension is lowered and I had to roll the arches a bit to avoid scrubbing.
This set-up (with GT3 adjustable lower control arms dialed in at close to -3 degrees camber) makes the car wonderfully balanced (basically got rid of the understeer).
Not sure about the off-set of the C4S (widebody) and 305's.
JP
