Hi guys, I want to install a set of GT3 sways, and needed to know if i need to unload the suspension or if i can do it while the suspension is loaded.
The reason I ask is that a buddy has a drive on 4 post lift that I can use however he does not have a jack on the lift yet.
So can I just drive the car on and undo the bars and swap them out or will they be under too much tension to get them off?
I assume that i can do it while the suspension is loaded as the bars should only be under tension when the car is cornering....correct?
Shalil.
No problem on a 4 post lift, under load or not make no difference as long both wheels are under the same load.
