I just found out that the fluid that is leaking under my turbo is coming from the water pump. Could this be causing the loud metallic can rumbling sound during idle and at 3000 rpm? Any instructions on changing the water pump for a 2003 996 turbo tip? Thanks
Broken impeller? very likely
Best to replace the pump (and look for broken water pump parts).
had a similar sound...2/3 weeks later my water pump ceased. Def. possibility to look into.
There is a recent
DIY for the water pump.
other than time and a few $, it would at least eliminate a common problem.
m
